relay ID help please - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    this relay cam with dads 67 L36 M35 with C60. on the bottom its marked 688
    thanks
  • Michael G.
    • January 1, 1997
    • 1251
    Re: relay ID help please
    Originally posted by Keith Brodbeck (14640)
    this relay cam with dads 67 L36 M35 with C60. on the bottom its marked 668
    Delco horn relay and (I believe) key buzzer should key be left in the ignition switch. Not sure what the application for your car is but could this be particular relay.
    • Keith B.
      • March 7, 2008
      • 928
      would someone have replaced the original 837 horn relay for this
      • Michael G.
        • January 1, 1997
        • 1251
        If 837 was the original....it appears so.
        • Keith B.
          • March 7, 2008
          • 928
          okay thanks. does this have any value? what years was it used on
            thanks
            Keith-----
            The numerical sequence is not "688"; it's "889". It's a derivative of part number GM #1115889. This is a horn relay originally used in PRODUCTION for 1970-71 Corvettes. It became SERVICE for 1966-69 Corvettes after the original relays were discontinued. In your case, the original relay was GM #1115837.
            • William C.
              • May 31, 1975
              • 6037
              Same Top. bottom plastic on the original was natural in color and did not surround the terminals.
              Bill Clupper #618
                Here's what the 837 relay looks like.
