The vertical fiberglass piece between the folding top compartment and trunk compartment has broken loose near the area where the power top micro switches mount to the bulkhead. There is an "L" shaped piece of fiberglass that is suppose to connect the bulkhead to the underside of the trunk compartment. I attached 3 photos taken from left to right in the folding top compartment. The "L" shaped piece is fully adhered on the passenger side, but as it goes towards the driver side it is broken loose and it drops away from the underside of the trunk compartment; making it difficult to re-glue it to the trunk compartment.
Can someone take a few photos in this area and show me what the "L" shaped connector piece should look like when it is fully adhered to the trunk compartment?
I am thinking about removing the "L" shaped piece and re-gluing it to the underside of the trunk compartment. I don't know if it broke completely off and bubba re-glued it in place. On the trunk side there are large blobs of bonding putting that has broken loose from the "L" piece of glass.
