Having a little problem getting the 62 to run smoothly.
A little recap with some details. Of course the project is taking longer than planned. I completed the chassis a year and a half ago. Engine rebuild complete, adjusted valves, electronic one wire ignition, AC 46 plugs, newly rebuilt FI etc. (bascially everything new). I set up a small panel with switch, starter button, ballast resistor and oil pressure guage so I could see if the engine would start. No cooling system.
With 93 octane pump gas, the engine started after a few trys (with a little starting fluid help) - ran beautiful and smooth. I would run it for 5-10 seconds then shut it down (no cooling system). I would restart 10min. later and do the same 5-10 seconds.
I repeated this every 2-3 months - no problems, ran smooth idled nicely.
Last Nov., before paint I ran it with 93 + a heavy dose of Stabil through the system because I figured it would be 6-8 months before I could start it again. It ran rough and smoked badly. I figured that was just the Stabil, so that's the way I shut it down and didn't run it for 6 months.
The next run (after paint) with the body on, I put 10 gal. of 93 pump gas in with an octane booster. Still ran very rough and smoked.
Now, two months later I changed the plugs (plugs didn't look too bad - one gap was way low) to AC R45S (someone suggested trying R45S) and started yesterday. Basically same problem rough and smokey. With increased throttle it seems like it would clear for a second, but, still would not idle. Hard to investigate because I don't want to run it for more than a few seconds without cooling.
The only thing left for me to try is to drain the tank (maybe too much octane booster) and put in Sunoco 110 (I found a local source @ $10/gal). I'll recheck the plug wires also to make sure I didn't cross two of them. After that I'm not sure where to go??
Could I have damaged valves? Running without coolant? Fuel filter problem?
Any ideas appreciated.
__________________________________________________ ______________________________
This morning (7/31/12) I drained the tank and put in 10 gal. of Sunoco 110 leaded. I checked the plug wires - all ok. I checked the distributor - it's tight, so I don't think the timing has changed. (can't check it because I can't get it to idle).
Started it and it seemed to clear. Shut it down and 20 min. later started it again. SAME PROBLEM, smoke (gray-black) and very rough - won't idle.
- I think it's getting plenty of fuel because it doesn't hesitate when throttle is increased.
- Timing seems ok, starts fairly easily and doesn't backfire.
- New plugs and electronic ignition, so spark shouldn't be a problem.
