'64 327 throttle linkage questions - NCRS Discussion Boards
  • Jeff H.
    • September 30, 1988
    • 53
    Hello,
    I'm in the middle of detailing the throttle lever and linkage on my '64 327 conv.. I have 3 questions that don't seem to have answers in the restoration technical "big book". I'm hoping someone out there can help.
    1. What is the correct finish on the lever (swivel) support bracket that bolts to the firewall? How about the 2 bolts?
    2. Is there supposed to be a gasket or sealer between the support bracket and the firewall?
    3. What is the correct finish on the lever under the dash? The book says cadmium or zinc plated. Mine appears to be dull gray in the area between the 2 nylon bushings. Is this the color of zinc plating?
    Jeff
    Re: '64 327 throttle linkage questions
    Originally posted by Jeff Hanson (13757)
    Hello,
    Jeff
    Jeff -
    The swivel that attaches to the tunnel is zinc-plated, as are the two attaching bolts, and there is no gasket. The lever/rod that contacts the accelerator pedal is dark phosphate, not zinc as stated in the JG.
