Headlamp Buzzer Wiring Confusion - NCRS Discussion Boards
  • Alger R.
    • September 30, 1999
    • 279
    Help! The optional tilt tele Steering column for 1975 also includes the headlamp warning buzzer (364079) option UF1. The buzzer connection to the fuse box is shown in the Assembly Manual on UPC 12L Sht 3. The problem is that I also have the power window option A31. The Power Window Harness which normally would hook directly into the fuse box per UPC 12H Sht 19 now has to partially tie into the buzzer instead. This is shown on UPC Sht 3 but is not clearly defined. It is very unclear as to which wire(s) connect to the buzzer. Does anyone out there have this setup and is able to describe the proper wire connections or colors?
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
