The factory apparently used a black tar like sealer around the heater box when leaks were detected. Do all cars have this sealer present and would there be a deduction during flight judging if it is not present? What product is being used to replicate this process? Thanks.
Heater box sealer
Re: Heater box sealer
Gene
I got a deduct at Kissimmee Regionals with my 390 car...I argued my point in a nice way that only the leakers got the "goop" treament, all to no avail...They wanted to see the sealant regardless...- Top
I took a couple of shots of a '65 in Bloomington that had the goop treatment. Not the best images but you get an idea how it looked...This car I think won best of show for a restored car.
Edit: I'm not sure this is correct...I would like to hear what other folks say.
- Top
From my research the material that was used to fix or detect leaks was sprayed on the heater box where it met the firewall. Note sure if the photos posted above look like the material was applied by spraying.- Top
I have to agree with Michael, it was sprayed or somehow poured on.
The attached picture shows the sealer applied on a 68.
JohnAttached Files- Top
How would an externally applied sealant prevent heater box water leaks? A ridiculous proposition at best, folly at worst.
Has anyone in this discussion considered that the externally applied material may have been intended to minimise offensive gaseous engine compartment vapor from entering the interior cabin, much like the sealant applied at other firewall to cabin gaps at the ballast resistor mounting hole, clutch boot, and other firewall to cabin openings?- Top
Mike- Top
I have a searchable PDF version of the '65 AIM...It does mention a sealant on page 227, I'm not sure this is the correct one.
I couldn't find anything in the AIM about a leak test either, other than the A/C system (Freon).
It's is documented in John's amazing Assembly Process document on page 22.
Edit: I searched for "Water" and turned up this in the AIM.
Mike- Top
Gene, EVERY 1968-1972 (and I suspect other C3s as well) got the "goop" treatment, and the AIMs call out that sealant on the heater box, and sealant on the grommets where the speedometer, tachometer and oil pressure lines pass through the Instrument Panel. Are you sure that midyears were hit & miss?Terry- Top
