Re: Sportsman Award questions
Mike,
It is not starting the car that the fire department is concerned about. The battery is an energy source. They are concerned about the sudden discharge of the battery by a short of the car's wiring. That could cause a fire. Disconnecting the battery, even if a small fuse is still in the circuit, protects against that possibility. Given a sudden large discharge of the battery the small fuse will blow and the discharge will stop.
I have to confess I don't understand why the fire department wanted the keys, but in my other life I have had many occasions to respond to electrical fires and I have learned when dealing with fire men you can't tell them a thing. They are singularly focused, and nothing will deter them, even common sense.
Mike,
But thanks again for your help here, you were correct about the engineers listening to customers about not letting a battery disconnect be a major issue requiring a lot of work by the owner. Now if only Honda would understand that, I changed the battery in my daughter's new CR-V and that required a trip to the dealer, as dealer codes needed to be input to get the nav and radio to work at all and activate the onboard alarm system. Glad Chevy is better than that at least. Cheers.
