erroneous speedometer, 66 coupe - NCRS Discussion Boards
  • Lincoln S.
    Infrequent User
    • March 29, 2009
    • 14
    I have a 66 coupe, stock wheels and tires, and have noticed that the speedometer reads low.
    For instance, when I am driving 55 mph the speedometer only shows 50 mph. Would I correct this with a larger or smaller speedometer drive gear?
    Thanks, Lincoln Singer, 50240
  • Michael G.
    • January 1, 1997
    • 1251
    Re: erroneous speedometer, 66 coupe
    Lincoln.....what is your rear axle ratio? The speedo gear for your tranny will color colded for the ratio. The gear, I believe, will fewer teeth.
    • Lincoln S.
      Infrequent User
      • March 29, 2009
      • 14
      Michael, thanks for the reply. My 66 has a 3:36 rear axle. Thanks, Lincoln
        • 15610
        You also need to provide transmission type and tire size/revs per mile. Also, get error readings at different speeds to determine if it's an offset error, gain error, or some combination of the two.Duke
