Paint Removal Using Dry Ice - NCRS Discussion Boards
  • Bob P.
    • June 30, 1998
    • 143
    I getting ready to prepare my C2 for painting and will be removing all the old paint from the car. I was wondering if anyone has had their car stripped by using Dry Ice Media Blasting? It seems like a perfect way to remove paint. No mess, the dry ice evaporates, so no left over residue to clean up on the car! If onyone has used this method or has knowledge of it I would like to hear the good and the bad. I live in Ohio and if anyone knows of someone in Ohio, Michigan, Indiana or Kentucky they would recommend let me know. Thanks for the help!
    Bob Puls, 30633
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Paint Removal Using Dry Ice
    • Michael A.
      • June 30, 1986
      • 68
      Hi Bob,t
      I have used Cold Jet. It is a magnificent process. Unfortunately when using it on fiberglass the results are quite slow. The process works very well on metal cars. You loose the temperature difference advantage on glass whereas the metal cars absorb heat and use the shock value of temp. difference. Otherwise it does a nice job, just real slow on fiberglass. Call them and ask for their opinion. Good luck.
      Later Mike Anderson (317)729-2418
      • Bob P.
        • June 30, 1998
        • 143
        Thanks for your help. Was your car completly stripped down? What did you have to pay to have it done?
        Bob Puls, 30633
