steering wheel removal from hub - NCRS Discussion Boards
  • Patrick M.
    • July 20, 2012
    • 50
    How do you get the steering wheel from the hub. It seems to be rivited on. This is a 1959 corvette. Thanks Patrick McPherson(55168)
  • John F.
    • March 23, 2008
    • 2395
    Re: steering wheel removal from hub
    You can buy a cheap puller or rent one from O'Riely's.
    • Donald H.
      • November 2, 2009
      • 2580
      Yes, the original steering wheels is riveted to the ball/hub assembly. To separate you can drill out the rivets. Suppliers such a as Paragon and Corvette Central sell a set of counter sunk head bolts to replace the rivetsDon
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • Joe M.
        • April 30, 1990
        • 1338
        Patrick, I recently drilled out the rivets on a C1 steering wheel. Make sure that you use a 3/16" drill bit as that is the diameter of the rivets. The countersunk bolts did not seat flush with the top of the steering wheel like the original rivets did so I had to ream out the holes with a countersink bit so that the top of the bolts are flush with the steering wheel like they were originally.
