C1 (58 - 60) Judging question about battery charger clips - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I know that the judging score sheet gives extra credit for battery shutoff, which I have. But my question is regarding the battery charger/minder attachment cable. I have the fresh new tar top restoration battery in my 1960. Still don't have the engine in yet, but I am keeping the battery charged by using the Battery Minder pigtail with the alligator clips. The charger also came with a pigtail that has ring tips that can be a more permanent installation onto the battery cable bolts. I know I could always install the pigtail after judging, but it would be much easier now with the engine out of the car.
    Will I take a judging hit if I have this installed? If so how much? The Chassis section of the score sheets list the 'Cables & felt washer' as 8 points where I suppose I could get a ding for originality as having something foreign installed.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Dennis C.
    • June 30, 2002
    • 884
    Re: C1 (58 - 60) Judging question about battery charger clips
    Don,
    I would suggest you remove it before judging. As for a deduction, it would depend on the judge. Some might dot it and take a point after a few dots, or some might take a point for having the pigtail installed.
    Dennis
      • 15573
      Did the charger not come with an attachment to plug into the cigar lighter? If not get one at your FLAPS.
      • Christopher R.
        • March 31, 1975
        • 1599
        Yes, you will take a hit in judging for having extra stuff. I don't know how much.
        • Donald H.
          • November 2, 2009
          • 2580
          Unfortunately that will not work since I normally have the battery disconnect open and the lighter receptacle is dead.
          Don Harris
            • 15573
            Ah ha. That makes sense.
            As others have said, you will lose some points for the additional wires -- maybe only one point, maybe more, depends on which side of the bed the judge got up on that morning. Can you not just stick to the clips?
            • Donald H.
              • November 2, 2009
              • 2580
              Yes, I'll just continue using the clips
              Don Harris
