I'm looking to buy a set of t3 headlights. My question is are the reproduction of t3 oem judge worthy by ncrs standards? Your insight is appreciated.
T3 headlights
Re: T3 headlights
Morris, the reproduction T-3 headlamps have a DOT symbol that the judges look for. NCRS standards are NON-DOT for T-3 headlamps.- Top
Re: T3 headlights
Morris,
The earlier reproductions had DOT embossed on the clear glass and was visible to the judges. The newer reproductions have the DOT on the back of the lens and out of sight to the judges. With that change the only way to differientate is the configuration of the filament itself.- Top
Re: T3 headlights
Morris, check out this previous thread wherein I posted a pic of the tiny DOT mark (apparently the earlier repos based on Dave's comments) in the #7 post:
https://www.forums.ncrs.org/showthre...ation&uid=4048- Top
Re: T3 headlights
Morris, if you're asking me, and if by "pass" you mean did it draw no deducts, the answer is "no". My earlier repos drew a 3 point deduct each time through multiple judgings. But as noted above, they are nice and bright for night driving, and are far less likely to fail during Operations Flight judging, which failures draw large (I think 25 points) deducts.
My repos did.- Top
Re: T3 headlights
Maury -
Forget original T-3's - they're about like kerosene lanterns in terms of brightness compared to more modern conventional headlights, and T-3's are 50 years old and are highly prone to failure (which is a 25-point hit in Operations judging). A full set of reproduction T-3's (made by Wagner Electric) are bright, reliable, and are only a 3-point deduction in Flight judging.- Top
Re: T3 headlights
My '65 has the reproduction T3 headlights. I looked at my most recent judging sheet and the sheet (section 12 Headlight Area) states that there is a 3 points per bulb deduction. However, the exterior judging team deducted only 3 points for my four headlights. Can anyone explain the confusion?
-Clark- Top
