54 horn pieces under button - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Anybody know exactly how the stuff under the button lays in there? There is the sleeved spring and the screws are insulated. Is the plastic notched piece supposed to be on the bottom? Abd the spring and multi holed round piece, whats the order. I cant find anything to show me in what order this stuff lays in there. Any help is greatly appreciated. Thanks folks
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 horn pieces under button
    Look at the 53 54 Chevy horn diagram
    It is the same
    There is a specific way the center metal peice installs
    It installs with "dome" up
    Dont tighten the screws down all the way or the horn will honk all the time and scare the pee out of you when you connect the battery.
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Guy M.
      • November 1, 1993
      • 499
      Thanks for the link Chris. On an unrelated subject, mt transmission dribbles a bit at the valve body gasket. I have tightened as much as I can without snapping a bolt. I dont know if the guy who rebuilt it used any kind of sealant. Are there maybe addatives thay seal it up or an I looking at having to drain it and replace the gasket. Thanks again
      • Chris S.
        • January 1, 2000
        • 1064
        drain and replace the gasket - I spray my gaskets with an adhesive vs using RTV -
        • Robert K.
          Infrequent User
          • January 1, 2000
          • 29
          Please remember to not paint the center of the steering wheel under domed center piece, that bare metal is the ground for the circuit.IMG_1037.jpg
          • Chris S.
            • January 1, 2000
            • 1064
            Yes !!!!! !!!
