At the point now of actually bolting things back on my 64. When my car was found after 35 years of hypernation the original carb was still on the manifold but no insulator spacer, or a baffle plate. We ran the cam in on a dyno after rebuild without these items. First silly question these are indeed factory installed items on a L75 engine? is there any adhesives between these parts?
1964 L75 carburetor istallation
Re: 1964 L75 carburetor istallation
Jef,
Yes, those are the factory pieces you need, the sandwich order is intake manifold, gasket, phenolic spacer then stainless shield and carburetor.
Make sure you get the correct gasket that has holes for the manifold hot slot and read in the archives about blocking this slot as todays gasoline will percolate much easier with all that heat on the aluminum carburetor.- Top
The SS plate is required to keep the exhaust gasses from eating the bottom out of the AFBBill Clupper #618- Top
Tim referenced that, I didn't. Haven't owned a Carbureted car for years, although I know the gasket sequence. I'd do a search on "manifold crossover" or "Carb Exhaust heat"Bill Clupper #618- Top
Jef -
Do a search using "hot-slot" as the keyword and you should get lots of hits.- Top
