Camaro ss fire in a trailer - NCRS Discussion Boards
  • James G.
    • May 31, 1976
    • 1556
    This is just a terrible event that occurred on August 4, 2012.
    BE SAFE OUT THERE......AND WATCH HOW YOU LOAD YOUR CAR. TRAILERING takes time to understand. Electric shut off switches are a must, and ''Don't haul gasoline in cans that can spill.
    http://www.chevyhardcore.com/news/vi...ire-in-trailer
  • Roy V.
    • April 8, 2008
    • 296
    Re: Camaro ss fire in a trailer
    That was just terrible to watch, I wonder how it started?
    Regards
    Roy
    • John D.
      • December 1, 1979
      • 5507
      That certainly was tragic and heart felt. I used to pound the interstates setting up at most all of the big shows. I saw more tragic accidents and fires along the interstates.
      A few basic things not to do. No gas cans in the trailer. Exception to that rule is if you have a approved fire rated gas can which few do.
      Always disconnect the battery. Disconnect means more than turning a green knob. Means pulling a cable off the battery.
      You see a lot of beat up trailers at the fleas and car shows. You also see a lot of 1st class ones.
      Check the trailer wiring as it doesn't take much to have a short.
      Why is it that guys hauling trailers have to pass everything on the road. Does that make them feel good? The truckers talk about this on the CB's as they see the results of hi-speed towing.
      • Clem Z.
        • January 1, 2006
        • 9427
        some states carrying gas in a trailer even in a approved container is against the law unless the trailer has a placard stating the type of fuel being carried. i guess that is to protect first responders
        • Kenneth B.
          • August 31, 1984
          • 2084
          That was one hell of a lock on the side door. Why wouldn't they let the guy use or them use the key? The older I get & the more of this kind of thing I see I am a lot more careful with a Corvette on a trailer.
          • Steven B.
            • June 30, 1982
            • 3976
            Way back when I worked for an organization that transported electronic gear in a trailer. To assure it was protected from total destruction in case of fire halon was installed. Expensive, but not as expensive as replacing a car.
            Steve
            • Michael W.
              • April 1, 1997
              • 4290
              I think the wife/girlfriend was lucky she didn't get sprayed with the hose. I wudda.
              • Clark K.
                • January 12, 2009
                • 536
                sniff, sniff. I smell a restoration project in the near future!
                -Clark
                • Kenneth B.
                  • August 31, 1984
                  • 2084
                  They were in a panic as I would have been. It sure didn't seem like they were in any hurry or seem to know what to do. They beat on the door & never did get it open. One guy stood there & was still putting on his gloves. Look at the vidio again & see if you would want them to put out a fire in your car/house
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    Pretty harsh comments especially when much of what's going on is out of frame. More than one firefighter has been killed by rushing unprepared into an unknown situation. It's a friggin' car and a trailer- not worth endangering anyone's life when the damage is already done.
                    The fire was out when they started to work on the side door, which is clearly open later in the video.
                    Let's see you do better..............
                    • Paul J.
                      • September 9, 2008
                      • 2091
                      The fireman tried the door first, and the owner was walking around close by. The video is not continuous, so we don't see if the owner tried his key. It probably didn't work on the heat damaged lock, as we can see by the efforts of the two firefighters who still could'nt get the door open with thier halligan tool (or pry axe, or whatever it was).
                      The loss is shame, and I hope he has good insurance.
                      Hey Clark, I wonder where the car is right now. I've always wanted a 69 SS, and condition does'nt matter.
                      Paul
                      • Kenneth B.
                        • August 31, 1984
                        • 2084
                        I was a volunteer fireman. If the fire was out why were the trying to rip the door open. The door that they opened was on the other side after the fact. I didn't say they should go rushing in the trailer as you said it was already ingolfed in flame & I can understand not getting close because of the chance of a explosion. You wre the one that made a comment about the lady. I wonder if you would have a ho hum feeling if it was your car trailed. That was all I was saying. Cut the lady a break.
                        • Jim D.
                          • 2882
                          A properly place hose stream would have shut that cow up.
                          • Keith L.
                            • April 7, 2008
                            • 378
                            Why is the first thing I notice in the pic is that the SS has a 10 bolt rear end??
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              it was a show car not a race car and you don't need a 12 bolt to drive it in and out of a trailer.
