I have a 90 Corvette with 6 sp manual. The speedometer and cruise stopped working. I had a error code 24. No other error codes. My question is : I removed my speed sensor from the transmission and measured the resistance of the pick up coil in my original sensor. No reading at all. So it must be the problem? Next question: Can't find an original 90 sensor anywhere. Aftermarkets are available for axle ratios 2.73/2.79. Mine has a black 40 tooth gear to go with my axle ratio of 3.33:1. Will the 2.73 or 2.79 work just fine if I use my black gear??
Appreciate any help
Fred Neitzel
Appreciate any help
Fred Neitzel
