C1 Grille Tooth studs - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I was at a recent event and was watching judging of a 1960. The judge commented that the grille tooth studs were to long, i.e. sticking out to far on the inside. The ones on my 1960 appear to be the same as the car that I saw judged. They are replacements.
    Corvette Central's website says theirs are the correct length, but does not give a length. I've emailed asking for the length so I can compare to what I have now.
    The ones I have now are 4" long and there is 7/8" of thread past the nuts on the inside when installed.
    Anyone have an original laying around that you can measure?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Donald H.
    • November 2, 2009
    • 2580
    Re: C1 Grille Tooth studs
    So I got a response from CC. Their studs are 3 3/4". I would still like to hear from someone with originals if this is the correct length.
    Don
    Don Harris
    • Thomas H.
      • August 31, 2005
      • 1053
      The originals on my car vary between 1/2" and 9/16" from the back of the nut to the end of the stud.
      Tom
      2007 Z06, Lemans Blue
      • Rod K.
        • 441
        My '57s are 3-3/4" long with about 7/8" thd each end. "Assume" they're the same as '60.
        • Donald H.
          • November 2, 2009
          • 2580
          Tom
          Thanks, that tells me what I needed to know
          Don Harris
          • Joe M.
            • April 30, 1990
            • 1338
            Donald, at the Lone Star Regional, the judges noted that the studs extended too far out from the back of the teeth. I don't know if they are original studs because I have not measure one, but I used a tap and cleaned out the holes and inserted the studs as far as they would go. Mine average about 5/8" with one at 7/8" inch.
            • Keith R.
              • August 31, 2001
              • 660
              I'm a little late chiming in - like four years! However, I am at this stage of reassembling my car and ran across this thread. For the good of the group, I cad plated what I believe to be original teeth studs on my car. They measure the same as Rod Kramer's. 3 3/4" long with 7/8" of thread on either end unlike the cheap Chinese ones which have different length threads at either end.
              Keith MacRae
              NCRS #36692
              New Mexico Chapter
              1960 290HP FI
              2013 427 Convertible
              Shade tree mechanic and
              B-52 pilot extraordinaire
              • Troy P.
                • February 1, 1989
                • 1279
                Yes originals are shorter. I have a set to sell if anyone needs them.
                Or you can cut off the repos. Cut the end that goes into the tooth. Otherwise the other end where you cut off the cad plating will rust over time if exposed.
