Brake lights - NCRS Discussion Boards
Brake lights
  • Richard M.
    Infrequent User
    • October 22, 2006
    • 28
    Brake lights
    Having problem with brake lights on a 65. Issue has progressed to point no longer have power when I cross the leads at the switch. Had power when I crossed the leads yesterday. Today bought a new switch and changed the fuse. The driving lights and both turn signals work fine. Now no power through the new switch or crossing the leads. Fuse is fine. If the issue is at the turn signal switch what do I look for since both turn signals are working fine. Also is there anything else to check before I pull the steering wheel. Really appreciate all help.
  • Richard M.
    Infrequent User
    • October 22, 2006
    • 28
    Re: Brake lights
    Solved my power issue. With new switch and fuses all appears to be working for now.
