I have a 65 Convertible which I have owned for about 10 years. When I bought the car I got the "motor was rebuilt about 5,000 miles ago" with no specific information available. The good news is that it was indeed rebuilt, bored and has 30 over pistons in it, but they are flat top.
And I have no real way to know what the Camshaft is either.
The good news is it was rebuilt, and not very long ago. I can still see the hone marks in the walls, and there is no ridge at the top of the cylinders.
I pulled the heads off it yesterday for a couple of reasons:
1. I have a #6 exhaust valve with a mushroomed stem that needs to be fixed.
2. I wanted to replace the press in studs with screw in type studs. I have a couple that are pulling slightly.
3. I wanted to see if I have a multi-angle valve grind, as per many discussion board posts this would improve low end torque on the 365 HP, and if not get one done.
My questions now are:
1. Will a multi-angle valve job still improve low end power now that I know I have a motor with flat top pistons in it?
2. I have a restored 380 FI unit that I want to put on the car and play with. I am not getting rid of the 365 carb and intake, just want to play with the FI, that I have been collecting parts for and had restored about 5 years ago.
Thank you all in advance,
George 36908
George 36908
