my 67 right rear lights blink together on the right side. the left side alternates from outboard to inboard like a RR crossing gate what could be the problem? they all work
turn signal rear light blink problem
Re: turn signal rear light blink problem
Craig that a look at the ground connections at the back of each light housing sound like one of them maybe broken or off.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
- Top
Do the light bulbs seem nice a bright(park and turn) as they would normally?each lamp has a ground and sometimes if one of the lamps is not grounded it will use the ground from the next lamp, this could cause a lamp to delay.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Ed, yes, when the parking lights are turned on all eliminate the same. when the turn signal arm is engaged they all have the same brightness, the two lamps on the right blink together as they should and the two on the left alternate, outer -inner. when the outer is on the inner is off, when the inner is on the outer is off.- Top
Craig,
Double check the ground as ED mentioned, maybe try a dedicated ground wire to another spot for ground as the wire connection may be dirty.- Top
Good luck on my way to carlisle this morning.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
It shouldn't be difficult to test the grounding of the lamp housing. With the t-signal operating, connect a jumper wire between the bumper and any part of the lamp housing. If the lamp then operates properly, you will know that the ground wire on the back of the housing is not connected properly.
The issue that you describe is VERY common. It's almost always a bad housing ground connection.- Top
