speedometer glass replacement C1's - NCRS Discussion Boards
  • Anthony S.
    • April 30, 1998
    • 156
    How does one replace the speedometer "glass" in a 53 - 55 car? Thanks Tony
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: speedometer glass replacement C1's
    Remove speedo from dash (2 or 3 screws) remove 2 screws that hole plastic lens in place and remove lens and replace with new one.
    Mark where bulbs go before removing although it is easy to figure out where they go.
    • Anthony S.
      • April 30, 1998
      • 156
      Sounds like an easy one, maybe not more than 1 hour....even with the dash in the car?
      • Bruce B.
        • May 31, 1996
        • 2930
        An hour +- depending on how easily you can fit under the dash.
