Guys,
I have a leak in the passenger footwell of my 66 AC equipped convertible. I know they all leak. Water is entering the footwell from the vent/grill assembly. When I pour water into the passenger cowl vent, water drains mostly out the cowl drain at the bottom of the car as it should. The drains are not plugged. However some of the water puddles on top of the adapter assembly (photo) then dribbles over the back edge. I can feel behind this edge and it is the fresh air opening for the vent door so this is how water is entering the vent area. The adapter assembly is shown C60 D2. Water enters in the area shown by gasket symbol 6. The gasket is a new gasket. The top of the adapter in the cowl drain area is almost like a flat roof with a lip. It seems to me the water flow should be directed away from this area but I am at a loss to figure out where to divert the water.
How is water supposed to flow from the cowl area over this adapter. Should I fill in this flat roof area with caulk?
