What is the difference between WCFB 3500S and 3501S? - NCRS Discussion Boards
  • Joseph E.
    Infrequent User
    • January 2, 2009
    • 19
    Would like to know the differences between the two Carter carbs that came with the manual transmission and powerglide versions of the 1963 327/250 base engines.
    Know from reading various docs that the WCFB 3500S came with the base engine/power-glide and the 3501S came with the base engine/manual transmission. What I can't find is any information explaining what the actual difference is between the two versions of the carbs.
    Anyone know?
  • David L.
    • July 31, 1980
    • 3310
    Re: What is the difference between WCFB 3500S and 3501S?
    One difference is the 3501S WCFB uses the 170-AD-588S choke and the 3500S WCFB uses the 170-AW-588S choke. I had a few 3501S WCFB's back in the 1980's but sold them after I sold my early 63 SWC (VIN # 1450). I still have a few 64-65 3697S WCFB's.
    According to my notes the throttle linkage on my 3501S WCFB was stamped "114-156". My 3697S WCFB's also have the same stamping on the linkage.
    As far as I know the 3500S and the 3501S WCFB's used the same top section (casting "6-1672") and the same center section (casting "0-1465" with "0-1451" stamped on the right side). The center section on the 3697S WCFB has a "0-1451" casting.
    Dave
    • Clem Z.
      • January 1, 2006
      • 9427
      there are no internal differences between the 2
