I am trying to figure out a way to buck 3/16" solid aluminum rivets by myself. The rivets hold the power top cylinder bracket nut plates to the underside of the trunk. My idea is to run the two bolts through a flat bar piece of steel, through the trunk floor, and screw them into the threaded nut plate. The top of the flat rivets will be under the bar steel and held firmly in place with the two bolts. Then I can use my air chisel with a self-made rivet setting attachment to peen the rivets.
The rivets I purchased are the same size as the original rivets, but the holes in the nut plates seem to be too large for the rivets. it seems like it would be easier to peen the ends if the rivets just barely slid through the nut plate instead of loose. I did not drill out the rivet holes in the nut plates. Any suggestions? Bad idea?
If I someone assist me, would a 10 pound sledgehammer head laid over the rivet heads be a big enough bucking bar?
. I'd be careful with any jokes as that size of a bucking bar can do some damage...to you
