Exhaust Tip Length - NCRS Discussion Boards
Exhaust Tip Length
  • Mike M.
    • July 24, 2011
    • 297
    Exhaust Tip Length
    Approximately how far should the exhaust timps on a '65 extend beyond the body? I bought some correct tips from CC. They seem mighty long.
    Tks,
    Mike
  • Jeff S.
    • July 31, 1984
    • 383
    Re: Exhaust Tip Length
    Mike
    There is no set or specified dimension for the tips. I find they look most pleasing when aligned or indexed using the downward/vertical sections of the bumpers as an eyeball guide. Observe from the sides; the bumpers' angle & the tips' slash-cut about even with each other.
    • Harry S.
      • July 31, 2002
      • 5258
      On my 63 I have them out from the bezel 5.5 inches. The rear bumpers stay cleaner from the exhaust and they look good. No problems with flight judging this year.
      • William C.
        • May 31, 1975
        • 6037
        Originals arw swedged to fit over the muffler outlet. Just push on the outlet until it won't go on more and clamp, just like they did it at the factory.
        Bill Clupper #618
        • Stuart F.
          • August 31, 1996
          • 4676
          On a 63, the galvanized heat shields will pretty much limit how far in you can move the tips. That is, of course, providing you are using the correct shields and original or correct reproduction tips. Either/or, it's a tight fit.
          Stu Fox
