I pulled my heads off because I have to get my valve guides replaced. They have .004 - .005" play. I am a rookie/newb and want to get these heads rebuilt so that they last a long time. I do not want to hot rod these, more like repair them and use any modern technology that makes sense. My car is a NOM 71 LT-1 with 49k miles.
Took my heads to two different shops today and got two different methods of repair. Now I am confused and could use/appreciate some advice.
Shop #1 - machine shop servicing many local repair shops
pressure test heads to look for cracks
replace all guides with new guides, not a thin sleeve
cut top of guide so a seal can be attached to it
replace all exhaust valves
Insert new exhaust valve seats - said this was needed to run unleaded (i already do)???
cut both valve and seat to match
check all spring pressures and heights - replace whats needed
NOT replacing intake valves
.010 cut across the bottom of the head to true the surface
clean & paint
price: $860
reco'd a thick fel pro that would lower compression.
Shop #2 - Guy builds race motors - full shop in his garage.
Drill guides and put in thin bronze sleeve
replace all valve, intake and exhaust
replace all springs
grind valve seats to match valves - without inserting new material/seats
no milling/cutting of the base
clean
price: $375
My confusion is the valve seats. Why is shop #1 putting a new valve seat in when shop #2 is grinding the valve seat? I was under the impression these heads didn't require leaded fuel. Is one of these guys overlooking something or wrong? Shop #1 warned me several times that when replacing the valve seat that he "could hit water and ruin the head". He said it rarely happens, but it is a possibility due to how the head was cast, that there could be a sand pocket......
casting # on heads - 3973487
Would like to know your opinions
clean & paint
price: $860
replace all springs
clean
price: $375
