I need some help in what I need to have connected to the transmission for this start up.
1) Since the electrical system is not in place I will not have the neutral safety switch hooked up.
2) Do I need to have the shift linkage installed so I can start the car in neutral or park or does it matter?
4) I thought I would have to find neutral anyways so I can check and add transmission fluid while the engine is completing initial run in or could I wait until I am finished and add the remainder of the transmission fluid at the very end.
Have not done an initial startup such as this so I have a lot of questions so any helpful advice is most appreciated.
John Lanning
