Re: Tri power lines leaking again
Excellent answer Doug, My pal Fi Art gave you that info and I am happy you used it.
Guys/girls you don't have to kill those inlet fittings to stop the leaks. Use what Doug told you. Apply it with a Q-tip holding back about 1-1/2 thread. Use can also use Loctite 545 on the ferrule of the line but don't get any inside the line.
If you insist on using SS lines and fittings 545 is your life saver.
For my fuel injection restorations I use a lot of the 545. But I use it sparingly. Great to use on the brass ferrules, the threads of the fittings etc. I also use it on vacuum line fittings, the inlet fitting to the fuel bowl. etc. Basically anywhere where I have a pipe thread. Now it's not permanent like the Loctite Red aka 271. That stuff is permanent. Wipe the excess off with Zippo lighter fluid and Q-tips.
Shake the bottle ofLoctite 545 every time you use it. Buy it from Traver's Tool (not Travelers), MSC Industrial supply and even Ebay. Not typically available in auto stores.
Thanks Doug. John
Thanks Doug. John
