If I recall, there used to be advertised in the Driveline a nicely machined fan spacer to replace the fan clutch for a Corvette. It looked very much like an original fan clutch hub but was, of course, solid. You could then bolt a fan to it just like you would an original clutch. The only thing obviously "missing" was the clutch unit itself. I checked the current issue and don't see it advertised.
Does anyone recall who made this and if it is still available? Trying to troubleshoot an issue with the orange 72 and I'd like to try a direct drive to the fan to see if it may be the new clutch itself. The regular aftermarket ones are, um, junk so I'd rather not use them if possible.
Thanks for any info you can provide.
Patrick
Patrick
