Is it better/easier to remove the hood with the hinges or without? Does leaving the hinges in place on the car make it easier to align the hood on replacement?
66 hood removal
Tags: None
- Top
Re: 66 hood removal
Over the years I've found it easier to remove the hinges from the hood. Mark them so you have approximate alignment going back on. I would not remove the hinges from the fenders unless there was a need to. This is a two person task. Easy to remove, little more difficult going back but not hard task at all.- Top
Re: 66 hood removal
I agree with Carl, removing the hood from the hinges is pretty easy with a partner. I use blue painter's tape on the hood along 2 edges of each hinge to get a precise location when it goes back on. I also slip a wash cloth or shop towel between the hood edge and the fender. Tim- Top
Re: 66 hood removal
Thanks Carl. Leaving the hinges on the car seems to be the best bet. Marking them to aid in the installation is a good idea. Thanks again.- Top
Re: 66 hood removal
Richard,
I have removed my hood a couple of times to do work on my 66. I have marked the bolt locations with a "sharpie" and just removed the hood leaving the hinges in place. The removal is very easy. Make sure you have a helper. One note, when reinstalling the hood I recommend careful adjustment before closing the hood all of the way.
Frank
Corvette Hood Removed.jpgFrank Clark
U.S. Army Retired, current serving DoD Civilian
C1 1962 300hp, 4spd. Black/Fawn
C2 1966 Coupe, L79, A01, C60, J50, M21, N40. Silver/Black
C20 1966 Custom Camper, L30, J70, M49, N40, G60, Saddle/White
C20 1966 Custom Camper, L30, M49, N40, G60, Saddle/White
- Top
Re: 66 hood removal
Now if you need to do alone - same cloths & perhaps a few more. Remove one bumper & grill that gets those hinge bolts exposed at the bottom which you can remove with the hood closed (not latched). Push hood up, slide cloths under edges all around & lift off.
Install in reverse order - lining up as needed.
Lots more work however very simple for a one man job.- Top
Re: 66 hood removal
Thanks. Marking the hood with a sharpie or tape before removal would give a good starting point when putting the hood back on the car. I will be calling on my friends to help me remove the hood, engine and transmission. They are always busy when I need help moving, but always around now that I have a 66 Corvette. Thanks again.- Top
