I just had my 71 LT-1 judged at a chapter meet. In the mechanical section of the test, the judge said the tube attached to the choke pulloff on the right side of the carb, should be straight, and not have a bend in it as mine does. As my judging manual does not address this question, I would like to know if this is correct.
I also had points deducted for having nuts with washers holding down the carb. The judge stated that the washers should be integral with the nut. The manual on page 56, specifically states that Holley carbs in 71 and 72 use nuts with flat washers under them. I also had points deducted for using the round black clip for the choke rod which the manual states on page 58, is supposed to be used on 71 and 72 carbs. The longer one which the judge said I was supposed to have, is for 1970 only, according to the manual. The final deduct in question is, the judge told me my carb was to have the thin paper gasket between carb base and manifold. I have the 1/4" thick insulator between the carb and manifold as per the manual on page 56. I would like one of you judges out there or someone familiar with the LT-1's to shed some light on this for me. Thanks, Mark
