removed the old door weatherstrip and replaced with the "molded corner" ones, sold at major vendors and that section is larger or puffeier and hits the body when you close the door. the old one did not have the molded corner. I can see that in the future that section is going to break down and tear from the constant rubbing. I could not have installed it wrong, it only fits with the flats in the 90` anyone else have this problem? and how did you solve it?
centered the molded section in the door radius,no door sag and my door gap is very equal all the way around. I did not have original weatherstrip to remove so I cannot compare the molded area for thickness. anyone have a original one to share?
