I would like to test my wiring harness and connections before I install the engine. Main reason is that if something is wrong, especially in the engine bay, it sure is easier to work on the harness with the engine out. I'm in the last stages, HOPEFULLY, of finishing my restoration. But I have not installed the engine/transmission yet.
I Think I can do the following which will allow me to test the harness for at least the lights, horns, turn signals, dash lights, etc.
1 Jumper negative battery terminal to frame
2 Connect other non-frame grounds to ground (e.g. the normal valve cover grounds like the wiper motor)
3 Connect the wiring harness wire that normally goes to the solenoid B connector to battery positive
4 I have the voltage regulator mounted to the inner fender and the wiring harness connected to it, but since the engine is not in, I don't have the VR connections to the generator
5 Don't have the coil in so wiring harness to coil connections are not made and distributor are not made
Will this work, or am I missing something? Again, I'm just trying to test all the lights, horn, etc.
Don Harris
Don Harris
