In reviewing the TIM & JG for 70 72 Corvettes, page 58, Section 4. AIR CLEANER, paragraph 3 discusses AIR FILTER ELEMENT.Starting with sentence 3, the description reads:
"An expanded screen filter has been seen on a few low mileage 1970 to 1972 Corvettes. The wording Best way to protect your engine.... indicates these as original. The gauge of the screen is smaller than current production. We have seen enough original filters and photos of engine compartments of new cars to conclude the correct original 1970-1972 air filter used an expanded metal outer screen. It had a vertical pattern, where the long dimension of each opening in the screen is in the vertical axis. The current AC filter with expanded metal outer screen has thicker metal and the lack of admonition, hot-foil stamped on the original filters, reading: BEST WAY TO PROTECT YOUR ENGINE -REPLACE WITH TYPE A 212 CW or A 329 CW."
In reading this description above, the first three sentences infer that since "Best Way" was present on a few low mileage 70 to 72 Corvettes and through lack of further description it should therefore be the standard for ALL air filter elements of this period? There are no details or descriptions herein regarding Open vs Closed air filter elements and their differences nor is there distinction between the design, markings or stampings of the 212 vs 329 filters.
Further, there seems to be a middle ground (ie: missing statement that closed the gap between the "few" and "current") where the description of the "few" ends after sentence 5 and the 6th begins with "The current AC..".
In reading many of the posts on this subject at this site, there are descriptions of what originals are believed to look like / read -vs- service replacements. There also seems to be debate about the extended use of "best of" during this period.
Should the description of Air Filter elements be revisited and expanded to provide additional clarity?
Questions I have:
1. Do ALL (both 212 and 329) filter elements ABSOLUTELY state "Best way".. OR are there some that exclude these words and begin with "Protect"?
2. Is there a difference in the wording/stampings on A329C -vs- A329CW air filter elements? (with the W referring to wetted) And then how about the mesh?
3. Seems they are all supposed to be yellowish in color (implying wetting).. but is the mesh different in open vs closed systems?
Questions I have:
