Electrical or other on a C-4 loss of power? - NCRS Discussion Boards
  • John J.
    • January 28, 2010
    • 3
    I'm driving my 93' when all of sudden I lost power--- twice! It was like the ignition was turned off. Pulled the car over and tried to restart. Both times the car restarted with no problems. I checked the battery connection and everything seemed normal. I noticed the oil pressure upon idle was low( just above the shaded area) but rose when power was applied. Car had been running ok before this happened. Anything else come to mind on why this would happen? Fuel pump?Thanks in advance.
  • Ken A.
    • July 31, 1986
    • 929
    Re: Electrical or other on a C-4 loss of power?
    ECM will shut down engine if oil pressure falls too low. Check codes, you may have a bad sensor.
