Esteemed collegues..Any pictures of a correct 1965 A/c 327 350 Hp or small block will be appreciated. I want to make sure all hoses and conncetions and bolts to brackets look correct...Thank You Bryan Hepper
1965 A/C pictures more help
Re: 1965 A/C pictures more help
Bryan -
The tLSEng1800.JPGRSEng1a800.JPGwo photos below should be helpful.- Top
Bryan,
If you have the 1965 Corvette Shop Manual Supplement (ST-60), it shows several "pictures" (they look like black & white photographs that have been converted into drawings, similar to the pictures in the Owner's Manual) that would probably be helpful, located in Section 13 on pages 12, 36, 37 and 38. The vacuum hose connection drawing is on page 39.- Top
Bryan,
There is a photo of a '65 or '66 being restored in John Hinckley's second presentation (from last year's national convention?). Slide #29 is a color photo showing the Evaporator Housing Assembly installed in an otherwise empty engine bay. There is a clear view of the STV valve attached to the Evaporator tubes and the Expansion Valve at the bottom of the Evaporator case. I think John's presentations are still available for download at the Michigan chapter's website.- Top
Bryan,
These may help. This is a '65 300hp setup. The compressor pulley is incorrect --too small, since corrected. Also the service port caps should be (are now) plated acorn hex style. You can see where I decided to locate the vacuum Tee. Didn't care for the "loop back" routing shown in the AIM, so went with a cleaner look.- Top
Bryan & Scott -Bryan,
Photo below ('65 A/C Evaporator) is probably the one Scott mentioned. After you click on the thumbnail and get the larger image, click on that image again to get an even larger one.
ACEvaporator.jpg- Top
Thanks John, that is the one I meant.- Top
