Hood Scoop Air Door - NCRS Discussion Boards
Hood Scoop Air Door
  • Pamela H.
    • August 8, 2012
    • 68
    Hood Scoop Air Door
    Can someone explain the hood scoop air door funcction?
    How is it controlled?
    I don't see anythin in the catalogs except that ther is a wiring harness attached.
  • Russ S.
    • April 30, 1982
    • 2161
    Re: Hood Scoop Air Door
    There is a switch in the forward driver foot well (up against the inner fire wall) that when the accelerator is kicked down contacts this switch and activates the air door. If your air door isn't functioning, this switch often needs to be reset. It tells how to reset it in the service manual but if I remember correctly, you push the switch arm all the way forward and then the next time you punch the accelerator down it resets.
    PS Check the service manual to be sure but I think you turn the key on before pushing the switch arm forward. Then with the key still on,push the accelerator to the floor.
    Diagnosing the system is covered on page 6M-42 in the service manual.
      Russ-----
      The hood-mounted actuating solenoid also has to be installed and functional.
