I'm having problems with the tach on my car. The needle bounces real bad ( I don't even think I can call it bounce) . On hard acceleration the tach needle will bounce radically ( between 1500 and 2500 rpm) usually between 2500 to 3500. It also bounces quite a bit when shifting but not as bad. The car has about 100 miles since a complete frame off resto. No parts were not restored or rebuilt. The tach and all other guages were restored by Roger Scott at corvette insturment service. The cable is new and lubed with no kinks or sharp bends. The distributor was completly gone through by Dave fiedler at TI specialties. I'm not sure how the tach mechanism works but am thinking the problem is in the tach. does any on e have any suggestions? Thanks for any input
69 tach problems
Re: 69 tach problems
Brad-----
My guess would be it's the damping in the tachometer instrument.In Appreciation of John Hinckley- Top
One of the things that most folks don't know is that a pre-1975 Corvette tachometer, while being mechanical drive, is NOT DIRECT DRIVE. Mechanical direct drive tachometers are used for some racing applications but I don't know of any stock application for them. Consequently, a Corvette tachometer uses a damping mechanism and that's usually where this type of problem lies.In Appreciation of John Hinckley- Top
Joe, the cable pretty much is a straight shot into the distributor that is the first thing I checked- Top
One of the things that most folks don't know is that a pre-1975 Corvette tachometer, while being mechanical drive, is NOT DIRECT DRIVE. Mechanical direct drive tachometers are used for some racing applications but I don't know of any stock application for them. Consequently, a Corvette tachometer uses a damping mechanism and that's usually where this type of problem lies.- Top
If the distributor is properly installed following the directions in the shop manual, and the drive gear of the distributor is properly installed (no directions in any Chevrolet publication, but lots of posts here) the tachometer cable will be an almost straight shot into the IP grommet and into the tachometer. There is a difference in distributor orientation between midyears and C3s and if a mechanic who only knows C2s installs a C3 distributor you will have tachometer drive and other alignment issues. That 90-degree device was designed to solve these self-created problems. If the distributor is installed properly, that 90-degreee device is a solution looking for a problem.Terry- Top
Brad, A couple of other things to look at, Is make sure the tach cable is attached correctly to the tach at the back of the dash, and I had a case where my tach cable had not been lubed, I removed the inner cable and lubed with some white lithium grease, this took care of my bouncing cable.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Brad you mentioned in your post having a new tack cable. This may not be a problem solver, but the formed ends of the cable may not be making a firm enough fit to keep from losing their grip in a connection point. A electric drill that can turn both directions could be used on the distributor end of the new cable to test your tach for operation if the fit of the cable is questioned. I can't say which direction it will need to be turned.- Top
