1965 Fuel Injection - NCRS Discussion Boards
1965 Fuel Injection
  • Jack B.
    • July 31, 1983
    • 37
    1965 Fuel Injection
    Need some info on a fuel meter ID tag for my 1965. The unit is a 380 with #2775. Car is a mid November 1964 build date.
    Engine block is I 9 4. I would like to order a tag for it since it is missing. What would be the correct date code for this repro tag?
    Thanks.
  • Paul J.
    • September 9, 2008
    • 2091
    Re: 1965 Fuel Injection
    Jack, call John DeGregory. He might be able to help you.
    Paul
    • John D.
      • December 1, 1979
      • 5507
      Thanks.
      HI Jack, I am back from the Fall Carlisle show although worn out.
      It is very helpful if one has the engine build date to establish a time frame for the tags. But you did provide the casting date so the engine assembly date has to be in September.
      But since your car is mid November then the Fuel meter "Inspection tag" most likely would be dated Sept '64.
      You need a Right Angle inspection tag to be 100% correct but no one makes that Right Angle tag.
      Typical repros (ALL) are Triangle tags. All three angles the same.
      For a start at least put on a repro so you get some credit for judging. JD
      • Gary C.
        • March 1, 1998
        • 236
        Hi John
        Do you have a photo of an original "right angle" tag so us posers know what to look for?
        Regards
        Gary
        • Will B.
          • July 31, 2006
          • 56
          The tag on my '62 unit is a triangle, from 1969, when I rescued it from the back of a gas station in Troy, NY??????
          It's brass.
          • Mike E.
            • June 24, 2012
            • 920
            Originally posted by Gary Cox (30260)
            Hi John
            Regards
            Gary
            I took these of a 65 FI this summer at Bloomington. I have no idea if they are correct.
            Mike
            • Jack B.
              • July 31, 1983
              • 37
              Thanks all.
              Very helpful.
              Did not know about the correct shape of the tag.
              Jack
              • Will B.
                • July 31, 2006
                • 56
                Mike, that looks just like the tag on mine!
                • Mike E.
                  • June 24, 2012
                  • 920
                  Maybe it is yours? Was it silver coupe at Bloomington this year?
                  Mike
                  • Will B.
                    • July 31, 2006
                    • 56
                    No, sadly, mine is a '62 in need of restoration. The two 380s I have are in two of the pictures in my 'tach reads twice cable speed' thread.
                    • John M.
                      • January 1, 1998
                      • 813
                      Here is what I believe is a correct 65 right angle tag, courtesy of John DeGregory.
                      John McRae 30025
                      • Will B.
                        • July 31, 2006
                        • 56
                        The old flat top unit has a brass tag with no right angle. It hasn't been touched in 41 years.
                        • John M.
                          • January 1, 1998
                          • 813
                          Maybe, but all the ones I've seen are anodized aluminum, yellowish on one side, clear on the other.
                          John Degregory may have some more info on these as this is his business.
                          • John M.
                            • January 1, 1998
                            • 813
                            Here are three more. The one in the middle is real
                            • Will B.
                              • July 31, 2006
                              • 56
                              You are right! I carefully bent one corner up and sure enough, it was aluminum on the bottom.
