water pump needed - NCRS Discussion Boards
water pump needed
  • Lawrence S.
    • April 1, 1993
    • 775
    water pump needed
    I have a 67 L79 and need a replacement water pump suggestion. I have judged my car and received a national top flight with a replacement water pump but don't recall where it came from.
    Any suggestions on what I should purchase?
    Lawrence
  • Jack C.
    • September 30, 1992
    • 1090
    Re: water pump needed
    Bill Mock. He advertises in the Driveline, 918 333-0748
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Frank E.
      • May 31, 1986
      • 189
      Try John Pirkle... He use to cary WPs but I don't see them advertised in his add. He's in the Driveline under Master City Corvette 706-855-1177
      Frank
      1966 Milano Maroon Roadster
      2004 CE Z06
      • Lawrence S.
        • April 1, 1993
        • 775
        I have tried him in the past he does not have any 67 L-79 cores left.
        I was hoping for a suggestion from NAPA or the like.
          Lawrence-----
          If you're looking for a properly dated and 100% as-originally-configured waterpump, Bill Mock is probably the guy to contact.
          If you are just after a pump using the original 3859326 casting, you might very well be able to get that from a local auto parts store in their REBUILT product line. The 3859326 is a very common casting and was probably used for a lot of rebuilt waterpumps. However, the pump will likely have a 3/4" NPT top fitting instead of the 1/2" NPT used for 1967 L-79. No problem. Install a bushing, carefully fill and "dress" the interface between the bushing and the pump casting and I don't think anyone will know after the pump is painted to match the engine paint.
          • Lawrence S.
            • April 1, 1993
            • 775
            Thanks Joe.
            • Mark S.
              • February 1, 2002
              • 110
              Another choice is ChevyCool. Ron and his work are excellent. Just had one done. He is in the Driveline 480 720-8000
              • David L.
                • July 31, 1980
                • 3310
                I believe that the water pumps have casting dates starting in late 1965.
                Dave
