C1 (1960) Heater Blower Ground??? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    Re: C1 (1960) Heater Blower Ground???
    Originally posted by Philip Porter (53007)
    Don, if you do not want the extra wire clean the surface where the fan attaches to the heater box, and the area of the clamp for the control cable of any paint this should give you a good connection when the fan is reattached to the box. As for the design the cable is a pretty good connection to the control panel which is grounded and original cars the fan mounting is not painted on the attachment side so the grounding with the screw was probably fine.
    Phil
    So here is what I did. Removed the blower motor/fan assembly then drilled a small hole through the fan housing and the Temp Control Valve bracket (the little arm where the capillary tube would have been) then put a screw through both. I don't have the fan back in yet, but I get good continuity with a meter.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
