C1 Valve Adjustment - NCRS Discussion Boards
C1 Valve Adjustment
  • Bob W.
    • August 31, 1981
    • 84
    C1 Valve Adjustment
    Just had the heads done because I had 4 rocker studs walking out. Now that I have things back together what is the best way to adjust the valves (stock 230 hp) both prior to starting and after
    • 15610
    Re: C1 Valve Adjustment
    Follow the static (engine assembly) hydraulic lifter adjustment procedure in any service manual. You adjust 8 at TDC #1, and 8 at TDC #6.
    Wiggle the pushrod up and down as you tighten the nut until there is zero clearance, then turn the nut approximately 3/4 turn, but anything between about 1/2 and one turn is okay.
    There is no need to readjust them after running the engine.
