Typical 65 fuel line? - NCRS Discussion Boards
  • Gary C.
    • March 1, 1998
    • 236
    Does the steel fuel line on this 65 small block look typical? My memory is a bit fuzzy but I do not recall the end of the line all jacked up like this one, should it be down by the frame rail?
    Thanks in advance
    Gary
  • William C.
    • May 31, 1975
    • 6037
    Re: Typical 65 fuel line?
    Typically a lot flatter to the frame rail. Line from the pump looks a bit long.
    Bill Clupper #618
    • Mike E.
      • June 24, 2012
      • 920
      Here are a few shots of mine '65 SB I took prior to disassembly. I think the end of mine was cut off so that won't help you too much. IMO it actually looks pretty close to yours.Guys…I realize the battery box and shifter are incorrect. They are both on my list.
      Mike
