What is the finish for the rear headlight housing link? This is the link shown in UPC 12, sheet A2, part #3953041 and connects to the vacuum actuator clevis. After blasting the rust, the piece appears to be either pot metal or aluminum. All of the other links/connectors are steel and I assume should be black but I'm not sure about this one.
70 Headlight housing rear link
Re: 70 Headlight housing rear link
Tom------What is the finish for the rear headlight housing link? This is the link shown in UPC 12, sheet A2, part #3953041 and connects to the vacuum actuator clevis. After blasting the rust, the piece appears to be either pot metal or aluminum. All of the other links/connectors are steel and I assume should be black but I'm not sure about this one.
DEFINITELY natural finish. I believe it's aluminum.In Appreciation of John Hinckley- Top
