66 L79 fuel pump - Will the work? - NCRS Discussion Boards
  • David L.
    • July 31, 1980
    • 3310
    Re: 66 L79 fuel pump - Will the work?
    Originally posted by Joe Ciaravino (32899)
    FYI:
    There is still much speculation on the meaning of that alpha code. The jury is still out on it.
    Joe,
    There is no question in my mind that the "alpha code" (2 letter code) stamped adjacent to the AC part number is the month and the year ("AF" = Jan. 1966, "LF" = Dec. 1966). The earliest code that I have ever seen is "LD" (Dec. 1964) on a "4657" AC fuel pump. I believe that the "alpha code" was not added to the "40083" AC pumps until sometime in 1967.
    Dave
    • Alan D.
      • January 1, 2005
      • 2027
      Dave, the "PT 5623145" is cast into the recessed area on the back side where the pump mounts to the block. Have many pictures, email me & I can sent you some. The "5A" is inside the round area where gasket goes. Also inside is 15324, the number 64 in two spots, a logo "P" inside a diamond. Outside is "MADE U.S.A." no "IN" since part of mold is left at that location. "S" on screws and have old pin/retainer. Also have a believe a "67" pump with similar markings.
      • David L.
        • July 31, 1980
        • 3310
        #18
        Alan,
        Around one or both of the "64" castings there should be "hash" marks (as many as 12) in a clock like fashion. Since the pump came from a March 1964 car I would suspect 1 or 2 "hash" marks (Jan. 1964 or Feb. 1964). You may need to clean the area and use a magnifying glass.
        Dave
        • Alan D.
          • January 1, 2005
          • 2027
          #19
          My "64" markings are inside only and yes one has a single dot mark. (see top left)
          The pump was removed in 1968 and kept until 2008 when it went back on the car.
          • Morris R.
            • May 7, 2012
            • 213
            #20
            Thank you donald that's a good point i'm finding it very hard in finding a metal bottom. Maybe that's the way to go although very expensive would you say? Keep in touch on what you do . Maury
            • William C.
              • May 31, 1975
              • 6037
              #21
              Depending on how correct you want it to be, there a number of unique features to the 40083 pump that are commonly not found in the replacements. The originals were cast of Magnesium, which gives a darker cast to the pump than an aluminum version. Also the originals had two wings to add structure to the dome. I'll get a picture and post it shortly.
              Bill Clupper #618
              • Joe C.
                • August 31, 1999
                • 4598
                #22
                Originally posted by William Clupper (618)
                Depending on how correct you want it to be, there a number of unique features to the 40083 pump that are commonly not found in the replacements. Thr proginals were cast of Magnesium, which gives a darker cast to the pumpthan an aluminum version. Also the originals had two wings to add structure to the dome. I'll get a picture and post it shortly.
                See post #6.
                Many of the OP's questions should be answered if he reads my article in the Summer 2010 Restorer.
                The OP is long gone. Maybe his questions were answered two months ago.
                • David L.
                  • July 31, 1980
                  • 3310
                  #23
                  Bill,
                  I have an original "40394" AC fuel pump (1966 Nova w/L79) that is quite dark so it must also be magnesium as well. It also has the "two wings" as you call them. I would call them "gussets" much like the gusset plates on a structural steel highway bridge.
                  Dave Liukkonen, P.E.
                  Civil Engineer
                  • William C.
                    • May 31, 1975
                    • 6037
                    #24
                    I would agree, I think I have the top from one of those around also.
                    Bill Clupper #618
