Re: CR on 1970 454
Pam------
The 1970 and 1974 pistons were different but the crown configuration is about the same. The bigger difference in the engines was the combustion chamber volume. The 1970 was about 100 cc and the 1974 about 113 cc. Therein lies the biggest difference in compression ratios.
If the shop wants to use OEM pistons, where do they propose to get them? As I mentioned previously, these have not been available from GM in years. They could be talking about Federal-Mogul 426P. However, these are a conventional cast piston. This is what the original pistons were made from but it's basically an obsolete material today. I would not even consider using them.
Pam------
