65 L78-The left side turn signals are not flashing when applied. It has a new switch, new wiring, new bulbs. The light, front and back comes on, and stays on, just no flash. Flash works fine when done manually. Driving lights work when on(both sides), brakes work fine when applied(both sides), Right side flashers work fine when applied. All lights come on when required, just no flash on left side. Wiring problems..AARRGGHH!!
Any help/suggestions would be very helpful.
Thank you
Thank you
Dr. George
) and check that the grounds are good. Good luck.
Pete
