While at the Frisco NCRS meet I began looking at exhsust clamps on the exhaust tips. I saw three different styles, one of which had the numbers 2171 stamped on them. The illustrations in the 1970-1972 JG weren't the same so I looked in the AIM on UPC 8-Sheets A2 and A3. Although the ones at the transmission and the ones at the exhaust tips appeared to be configured alike they had two different part numbers. For some reason the guillotine style seems to be the accepted standard for 1970-1972. The AIM part number for the exhaust tip clamps is 3982171 which agrees in style with the ones I bought in Frisco. The clamps at the transmission part numbers are 3848157. Who sells the ones at the transmission that will pass judging standards?
When I looked at my over 20 year old exhaust system where it passes through the crossmember there are four clamps there because there are two transition pipes that pass through the crossmember instead of two long pipes that meet up with the header pipes. Looks factory.
Scott Sims
Texas Chapter
Scott Sims
Texas Chapter
