Re: Correct C2 Exhaust Clamp Vendor
Jeff, just realized that the number on the clamp is a pattern number. Search shows it was issued around Oct 1955 to a Riker. As you can see from the picture the pat. no. was not restricted to the clamp size.
However that in no way means that either are not GM clamps.
If it turns out these are the correct clamps then the nut used for 2.5 was different then that called for on the 2.0 clamp, pn 273802.
Did a search of an old catalog - (Oct 1, 1963)
2.0 U Bolt, exh. pipe clamp (5/16 - 18) Gr 3.708 pn 3824283
2.5 U Bolt, front exhaust pipe clamp (5/16 - 18) Gr 3.708 pn 3824528
2.5 Clamp Unit, exhaust muffler (2 1/2"pipe) Gr 3.708 pn 2378616.
Another one was also found 62-64 Corvette Clamp Unit w/U-bolt, exhaust pipe and muffler (2" pipes) (stamped 3754883) pn 3754883
