My power steering works when cold, after driving 10 min or so or a high rpm run threw the gears I loose P/S. I have a new pump, new control valve, and new lines , can anyone make explain this condition. The only part to change is the cyln.
Power steering problem l36
Re: Power steering problem l36
Hi James,
I'm bringing you back to the top of the list. I have a similar problem with my PS after it warms up.(Noisy when you turn) It's not new and I thought I might need to replace something. I'm interested in your responses.
TerryTerry Buchanan
Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
Corvettes Owned:
1977 Coupe
1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
2003 Electron Blue Coupe
2019 Torch Red Grand Sport Coupe- Top
James
That is why I ask the question if you had no problem before you started the parts replacement then it could have been 1 of the items you replaced. With that being said sounds like your cylinder the seals inside are sealing when the oil is thicker cold then when the oil thin out when heated. So I would say your cylinder is the problem.- Top
Hi James,
Glad you solved the problem. Were you replacing all the power steering parts with replacement parts or parts that were rebuilt originals and if so, whom did you use?
TerryTerry Buchanan
Corvettes Owned:
1977 Coupe
